Configures RIPng on an IP interface.
| vlan-name | Specifies an IPv6 configured VLAN. |
| tunnel-name | Specifies an IPv6 tunnel. |
| all | Specifies all IPv6 configured VLANs or tunnels. |
N/A.
For RIPng to be active on the interface, it must also be globally enabled using the command disable ripng export [direct | ospfv3 | ospfv3-extern1 | ospfv3-extern2 | ospfv3-inter | ospfv3-intra | static | isis | isis-level-1| isis-level-1-external | isis-level-2| isis-level-2-external | bgp]. If the keyword all is specified, all IPv6 configured VLANs or tunnels will be configured for RIPng.
configure ripng add finance
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
